Ok, this is just getting stupid. I’ve been BEGGING for months to not leave the name property field text highlighted after renaming an object. Besides the obvious PITA of having most of the objects I carefully name get renamed because you insist on leaving the entire text highlighted after one changes the name property which results in all my careful naming to self document construction lines / history and whatnot being utterly wasted because they all get renamed again with whatever you type next (my Rhino projects have thousands of items named “move” / “copy” / “line” whatever) here’s yet another fatal bug.
Don’t ask me for a project file because you don’t need one. READ the instructions. If I sound pissed it’s because I am. I’ve had it with this one thing causing so damn much grief.
So here’s the FATAL crash due to the stupid behavior of the name property field remaining highlighted after one changes the name of objects.
Drawing a couple objects. Does not matter what they are, lines rects, it’s irreverent.
Select them. Go to properties and name them anything. Hit return. Now go to Edit / Groups / and group them. Instant crash.
FFS this is like the 3rd or 4th fatal bug related to the asinine practice of leaving the text highlighted after renaming and while you keep fixing the symptoms you never address the cause.
If I wanted to continuously rename stuff I’d reselect the text in the name property field and do it again. I don’t need you to keep the text selected for me only to utterly waste hours of careful naming of things to have that all lost because of this behavior.
Please fix this as it is reaching a boiling point for me that I’m ready to go back to autocad. At least with autodesk they make it clear they could give a rats ass if the 20 year old bugs ever get fixed.
This has been going on now since V5 and I’ve filed literally dozens of bug reports on it that for whatever reason your system ignores all the mac generated crash reports. Why even bother having a crash report mechanism it if it just goes into the bit bucket and gets ignored?
Sorry but I just lost 2 hours of work due to this and it’s not even close the first time that damn name field thing has cost me a bunch of time.
The auto save thing doesn’t help me as my files are on a NAS which doesn’t support Apple’s behind the scenes auto versioning auto save hocus pocus. So my choices are to save every few minutes manually and put up with Rhino harassing me for my frequent saves which leads me to yell at it “if you din’t friggin crash all the damn time I wouldn’t have to save so friggin much”.
Pardon the rant, but I’ve had it.
