So I got the latest bug fix release. All the property name bugs are still very much alive and well.
Rather than focusing on the symptoms (myriads of fatal crashes) how about we focus on the cause?
HOW TO REPRODUCE AT WILL
- Create anything. Doesn’t matter.
- Select it.
- Click in properties / name field and rename it
- Hit return
- Do pretty much ANYTHING else.
- Crash
Stuff I know in step 5 that will kill it:
Export Selected
Boolean (any variety)
Group (or ungroup)
Create Block (or explode) or any thing else block related
Any Solid Edit Tool Submenu item
Any Curves Tool Submenu Item
In short the problem is 100% related to leaving the damn name field in focus when you hit return. Pretty much anything you do after that (particularly menu based stuff) will cause an instant crash.
HOW TO FIX
The solution is simple. Just kill the focus in the property name field once you hit return after naming something. There’s absolutely ZERO good reason to leave the field in focus. If someone screws up typing the name they can reselect the field and rename it.
WHY THIS NEEDS FIXING
Because 95% of the time the next operation is something else. A command line command, menu command, etc, and the vast majority of these will cause a crash.
Why else?
Because we rename stuff for a reason. And it doesn’t help with the damn field remaining in focus and typing a command that now not only doesn’t take but renames the object to the name of the command completely wrecking the whole point of naming something in the first place.
This bug has been here for a really damn long time now, and I’ve encountered in various forms always reporting them as what I was trying to do AFTER naming something, and thus the number of crashes was limited to what I tend to do AFTER renaming something.
So please, address this. It’s been causing me to lose work since V5, and a LOT of lost work in the last 6 months as I’ve migrated my files to a NAS Raid 10, and it does not support the persistent storage stuff that Apple uses for autosave and internal versioning, so when I crash? I lose everything since the last save and in the last six months this bug in it’s various forms have cost me hours and hours of work I’ve had to recreate.
Its not your fault my stuff is on a NAS, however after losing an entire weeks worth of work when an internal SSD died (I run full backups every sunday night at 4AM, and it died saturday afternoon) moving files on a raid 10 NAS makes sense.
VERSION / ENV STUFF BELOW
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.17002, Git hash:master @ b109c0eb42133053936614c484cb870a02a53b49)
License type: Commercial, build 2021-01-12
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G3020) (Physical RAM: 96Gb)
Mac Model Identifier: MacPro5,1
Language: en-US (MacOS default)
AMD Radeon RX 580 OpenGL Engine (OpenGL ver:4.1 ATI-2.11.21)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8 GB
Graphics: Radeon RX 580
Displays: LG HDR 4K (271dpi 2x), LG HDR 4K (271dpi 2x)
Graphics processors
Radeon RX 580 (8 GB)
LG HDR 4K (3200 x 1800 @ 60 Hz)
USB devices
Genesys : USB3 Reader
Kensington: Kensington Slimblade Trackball
3Dconnexion: SpaceMouse Enterprise
Apple, Inc: Apple Keyboard
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
com.3dconnexion.driver (1.1.3) 7F3D461C-BC8E-3D27-A964-2FCC8BE205E2
com.rim.driver.BlackBerryUSBDriverInt (0.0.68) 5794FFBC-214B-B40A-95A5-07DA0A6402B6
at.obdev.nke.LittleSnitch (5470) A938A4D4-0642-39B0-A99E-4FA69C7F9660
com.dvdfab.kext.fabio (1) no UUID
com.kensington.trackballworks.driver (1.5.0) DB29005C-2B91-3805-A070-DE97F5D7061F
com.AmbrosiaSW.AudioSupport (4.1.4) no UUID
com.malwarebytes.mbam.rtprotection (4.6.12) EB8FB437-AE7D-3B5D-AD84-0CDB871BDBB0
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.2.21012.17002
