Bug: (Heads Up)
I am encountering frequent crashes when editing block attribute text. I am trying to get a reproducible sequence. However, changing existing text on the properties panel results in crashes frequently.
I am convinced that this bug is related to changing the KEY before changing the VALUE. I am not sure the combinations but this crashes only happen when I have accidentally changed the KEY and but it back then change the value.
The problem is just editing the key the editing the value does not cause the problem.
Thanks for reporting -
I was able to reproduce that crash here.
RH-64408 - UserText: Aborting key name change crashes Rhino
