XNurbs installation issues
Have purchased Rhino7 and XNurbs. However, I cannot validate the license. Downloaded latest XNurbs for Rhino7 .rhi from XNurbs website. Ran installation. Opened Rhino7, to be greeted by:
Rhinoceros 7 XNurbs License
Cannot find a valid license. If you have purchased a software key, please make sure you’re connected to the internet and activate the key.
Error Code 17: The function failed because this instance of your program is running inside a virtual machine / hypervisor.
Would you like to run xNURBS License Manager and activate xNURBS plugin?
Notes: I have purchased a license, I am connected to the internet, I AM NOT running inside a virtual machine / hypervisor (I have even attempted installation and registration with Anti-Virus completely off). I run the License Manager. I go to the “Standalone / Cloud” tab, input my license number, I click “Activate”, and I receive the following message:
xNURBS License
Rhinoceros is running. Please exit Rhinoceros and then refresh/activate/deactivate xNURBS license.
So, I close Rhinoceros, leaving the xNURBS License Manager open. I click “Activate”, only to receive the following message:
xNURBS License
Cannot activate the license. Please make sure you are connected to the internet and then try again.
Notes: I am still NOT running in a virtual machine / hypervisor. Under the “Status” tab of the xNURBS License Manager, “Refresh License” is grayed out. Under the “Standalone / Cloud” tab of the xNURBS License Manager, “Deactivate” is grayed out. This is a dead end.
Any help or suggestions will likely be appreciated.
When did you purchase Rhino 7? Did you purchase it from an McNeel or an authorized reseller?
Had the license for a couple of years. Downloaded and installed the latest revision yesterday. Purchased from McNeel
Hi Christian -
For help with XNurbs, you might want to reach out to the developer directly.
I recently ran into this issue as well; I am running Windows 11 Pro / Rhino v8 / Latest version of xNurbs and some 3rd party host based security software. The following link resolved my issue (see bottom of post), more specifically Method 2: Core Isolation. Keep in mind “Core isolation is a set of virtualization-based security features on Windows 11 (I believe it is also on 10) that provides additional protection from hackers and malicious code. One of the main features is “Memory Integrity,” which prevents malware and other malicious code from hijacking high-security processes.” As a side note, I also run Mesh2Surface for RE work and I had to re-activate it after disabling Core Isolation. Finally, Core Isolation is recommended to be enabled, but not a requirement; a proper defense-in-depth strategy and OPSEC while online will make up for this single feature being disabled. I did not try and re-enable after I got all the things working again. Also, it can cause a performance hit while enabled (on) for such activities like gaming and I would imagine CAD work with large meshes / files.
Link: The function failed because this instance of your program is running inside a virtual machine / hypervisor - Hitmix Bingo Knowledge Base
Just to give you a heads-up, the VM restriction can be turned off from the developer’s end, and the man behind xNURBS intentionally has it on for no reason.
I have the same Problem with Failure 17 and the virtual Machine in Windows11. I bought Rhino 8 & Xnurbs in a bundle. Rhino is working with key… But xnurbs make those known old problems… I had deactivate the corething, nut the failure is still the same
Installed WSL (Windows Subsystem Linux) for running Anthropic Claude-Code, it apparently enabled the Windows “Virtual Machine Platforms”. This gave me the X-Nurbs error 17.
Disabling it in Windows Features was the answer to the X-Nurbs license issue.
“Virtual Machine Platform” is a Windows feature that provides underlying virtualization support for:
  • WSL 2 (Windows Subsystem for Linux version 2)
  • Hyper-V containers
  • Platform support for virtual environments
It’s a low-level component that enables virtualization-dependent tech to run, but does not provide a full GUI or management interface like Hyper-V Manager.
