theLatest xNurbs incompatible with SR7.38?
Does this imply that the latest xNurbs Plug-in is incompatible with RhinoV7?
(Result: installation was unsuccessful.)
_
@dale,
The issue is that I am unable to use XNURBS owing to a limitation in V7, despite having purchased the license for XNURBS. The image appears to indicate that I would need to upgrade Rhino in order to use xNurbs. What would you do if someone has a meaningful conversation about RhinoDev, yet the Ver. 8 Dev and McNeel services do not meet my expectations?
The term “service” refers only to a person’s quality (to me) at least…
Does this make sense to you?
Problems with a third party plugin need to be directed TO THAT THIRD PARTY, and it’s up to them to figure out if the issue is with the plugin or Rhino.
You are being extremely obtuse and obnoxious, so I’m going to mute you now, good luck getting help from anyone with that attitude.
I purchased Xnurbs in Dec 2024. It has been working really well for the last 4 months.
About 3 to 4 weeks ago it stopped working. I do remember a Rhino update came out around that time. I also recieved an update from xnurbs about 2 weeks ago. I downloaded the new Xnurbs update. Since that point, Xnurbs will not load into Rhino’s plugin folders. It immediately shows an error when Rhino 7 opens up. Says “Error Loading” in the details it says. “Unable to load XnurbsRhino7.rhp plug-in: Initialization failed” I just reverted back to Rhino 7 sr 37 to see if that fixed anything. That did not fix the problem. Been having a very long back and forth conversation with some tech support guy at xnurbs. I think I might be talking to someone at some kind of call center. Not much tech support or any tips or suggestions from them. So I will just keep trying to get it working again.
@XNurbs - Can you jump in here?
Are you sure to have downloaded the Rhino 7 version of the plugin?
They do have different downloads for Rhino 7 and Rhino 8.
Just a thought.
I am using XNurbs 7 without issues under Rhino 7.38
For XNurbs support, please visit Contact | xNURBS
