Wrong texture mapping from import of .skp to rhino
SKP and 3DM download link:
Try the check box labeled “Use the SketchUp Texture Writer to create textures” when opening the skp. This works here in v5.3.2
Any luck?
I am sorry… I have searched for a while in google… and tried some downloads.
I could not find the right extension to use.
Would you like to provide the link to help?
Great thanks !!
I just used the check box for that option when opening the skp file in Rhino for Mac 5.3.2 so no other download or app should be needed. Are you using a different version of Rhino?
This is checked, but the problem still exists..
I’m not sure why that’s not working for you with the model you posted.
  • Did you change the model or are you using something different now?
  • What version of Rhino for Mac are you using? Look in the Rhinoceros drop down menu>About Rhinoceros.
I am using Wip 5.4 rhino mac
Oh I found the problem!
It is totally fine when I import it as mesh but not trimmed planes.
Thank you very much!
Hi, I was wondering if I could get permission to download the file from the drive, I could use your 3D for my site model. Thanks!
