Is there a way to update attached worksession files without opening the worksession manager? I have a few big files attached and it can take some time to load.
Hi Matt- I am not sure I understand the question -do you mean selectively update some but not all of the attached files? You can select the file to reload in the Worksession dialog and update that one only- is that what you mean? The non-dialog version of Worksession (-Worksession) seems to only refresh all attached files, there is no way to select only some. I’m pretty sure I am not getting at what you need…
That’s it, the non-dialog version. It was taking awhile to open the worksession dialog and I was looking for a way to refresh files without opening the dialog. I didn’t know that was there. It does seem to only refresh the ones that have been changed, not all. Although it doesnt seem to be much faster.
Thanks!
Right, sorry, that is what I meant - but there is no way to get at a particular file or files among the out-of date ones, which you can do in the dialog. I don’t think it would be much faster… but are you saying there is a lot of time taken to just open the dialog in a worksession with large files?
I guess slow is relative. It can take up to 10 seconds to load the dialog box. Not terribly long, but was wondering if there was a way to speed it up.
Hi All,
this is more related discussion for my question. Is that possible to implement a tab in the docked windows with the worksession manager? Please see the attached image:
Wow, I’m just now just reading this topic and it’s 5 years old. Is it possible to expose the out-of-date files in a work session such that a visual warning appears when the file on the hard drive is newer than the file that was referenced at the start of the work session. AutoCAD does this…
As soon as a .dwg file that is x-referenced is opened and saved and its save date/time now “newer” than the date/time that file was “loaded” in your current host file you will get a visual warning dialog that announces the mis-match and gives you the opportunity to click a button and reload the external reference file. So AutoCAD is actively monitoring the external reference file creation date and will notify you when it’s newer.
Well it’s Rhino 8 now and the Worksession management is still incredibly SLOWWWWW.
Something HAS to be wrong with the way memory is managed with this tool.
It makes no sense that it would take so long to access the WS management options by right click or to get the WS manager to show up.
It feels like it is re-loading the file each and every time for nothing.
It really defeats the purpose of the tool.
Hi everyone,
I would like to point out, that this is stil an issue.
The time to open the Worksession manager is somehow depends on the total size of the attached files. When you have multiple big files attached, it is painfully slow then.
Is there at least a chance to bypass this manager by some direct api call until it is fixed?
Thank you
the non dialog -Worksession trick didn’t solve it?
Hello. Thank you for your reply.
It seems that this command works better.
