The current workflow that I use to create exterior elevation drawing is to insert a section line on the exterior of the building. However, the current approach does show the swing lines or sliding lines of the doors and windows. The current opening elevation tool is able to show the swing/sliding lines. Will it be possible to integrate this option into the section drawing as well? I have attached a picture of what I would like to achieve.
Hi @Julius3 that feature is not possible right now, unless you create these doors or windows as Grasshopper styles, which integrate the opening lines in the 3D model (like this example: Hinged door with handles set | Food4Rhino)
I take note of this request for future versions.
