Is there a way (other than exploding) of changing the direction of the triangle in opening elevations? See image for reference. Door/window elevations in VA follow the convention of having the tip of the triangle pointing in the direction of the door hinges. We follow the opposite convention, where the triangle points to the door handle (dashed line in red)
Hi Filipe,
Unfortunately, this is not possible in VisualARQ 2 and neither in the upcoming VA3 version. You will need to explode the opening elevations and draw the opening lines manually. I hope we can work on this feature soon. I’ll keep you posted.
Hi Francesc, was this ever worked on? Is it planned for future versions? In the UK it is standard that the opening lines are the opposite way to that in VA.
Hi William,
We haven’t implemented this feature yet. We will do it in future versions. There are some window and door styles (created as Grasshopper Styles) on food4Rhino that have this feature:
