Can you make the option to import a file (dwg) to the current view and not to its original top view.
Like the way insert is working.
If tried to use -insert but it imports my lines as a block. and i don’t want that.
And if i use -import it’s always going to the top view plane.
you may also want to check:
_selLast (to select all new objects from the last command)
and
_remapCplane (…)
if you need those workflows more often, i recommand to have a look at macros
https://wiki.mcneel.com/rhino/basicmacros
kind regards - tom
