When I try to insert a dwg files, and the files are successfully inserted, I can see the different layers of those stuff, but there is nothing can be see at any view. No matter top, right or left. I can see the files are inserted but just no thing shows
Hi David -
We’ll need more information to be able to figure out what’s going on there.
For starters, please run the Rhino SystemInfo
command and copy-paste the result here.
Then, also post a simple 3dm file, and, depending on how you inserted, the dwg file that we can use to try and reproduce the issue.
Also, try Zoom
Extents All (ZEA) - or SelLast
and Zoom
Selected (ZS) - it could be the inserted file is in state plane coordinates or something and is somewhere in the distance…
