But if often need to see the textured mesh when I manipulate it, so I really wish for the ability to only show the contour as selected, and not the mesh faces.
I guess a very easy to implement solution that would solve all my needs is a transparency slider for the yellow shade color.
If I could choose to set this from 0 to 100 % then I would be very happy indeed, and that should not be an impossible wish as the yellow shade color is already semi transparent and shows through part of the texture.
Pretty Please!
It would make working with scan data so much easier!
Yep, I hear you - I’ve lobbied for different selection ‘looks’ for this reason - very hard to see color and material changes, let alone other objects when everything turns yellow.
