The new feature in Alias’ round tool (which I think is similar to Rhino’s FilletEdge tool?) where you can Alt-Click on a fillet point and it selects all other points with the same value would be really nice to have in Rhino as well!
I find that I’ve needed it quite a few times when there’s a lot of fillet points to edit in the same command. I try to do all my filleting in one go so that I can edit all fillets that I’ve done, rather than having to undo one round of fillets if I need to edit a value that was in a fillet before it.
That does NOT (fixed) seem likely in Rhino anytime soon.
In Rhino, fillets are just surfaces that are degree = 2 and tangent to two surfaces.
Based on the description, I’m guessing Alias may have a fillet “feature” (or something like it), so they are not simple surfaces. They may be a new object type with adjustable parameters.
Hi Vince - so, in the FilletEdge UI, once ‘handles’ are set, you would like to be able to edit the radius all handles that have the same radius as the one you select, at the same time, is that correct? RH-80846 FilletEdge UI - adjust same radius handles together
During the FilletEdge command (whether I’m editing a pre-existing fillet or creating a new one), I’d like to be able to select all handles with a similar radius by Alt-clicking or by pressing some other key simultaneously when select one of the handles, similar to how Alias, well… handles it.
An example of it is at 2:39 in this video that eobet shared in the other thread:
