I’m filleting multiple edges of a solid and I want them all to have the same fillet radius. It’s very time-consuming to select each handle individually. There must be a way to input a radius once for all of the selected edges.
Thanks!
Thanks!
The only way I know is to set the radius before you select the edges. Hopefully someone else will chime in with a better answer.
Hi Jim- use SetAll at the command line.
Thanks. Knew there was an easier way.
Wow, fast response! Sorry to ask a question which was answerable with a visible option…
Thanks for your help.
