Wish: Remove selected objects from Named Position
Is there a command to remove selected objects from Named Position ?
As workaround I cut and paste the objects and then delete the copied named position. But It can be a problem if there is history or IK links attached to these objects.
Hi Alan - for now, select the objects that you do want to keep in the named position, highlight the named position in the panel and in the context menu (Right click) choose ‘Save object positions as named position’ and OK the overwriting of the previous save. Does that work?
Yes, it works, thanks ! Much better than my workaround.
