Wish geometry pipeline with delete input after solver
I am running into some limits using the grasshopper player which I hoped would have been solved with rhino 8.
What I would to achieve is the following:
start command >> get all geometry from layer X (geometry pipeline) >> modify geometry >> bake new geometry and delete old geometry.
For the input node “get geometry” there is this option “delete input after solve”. The only thing is that I do not want to have to select the geometry when running the command.
I do also want this feature. Meantime somebody will figure-out how to create a component to do this you can use something like this:
Delete.gh (7.2 KB)
