Wish: copy mesh options copied from existing file
Could you please make a browse button in Rhino Options so that mesh custom options are copied from a existing file?
I hate to adjust this every time if I forget to start the file with my template.
Thanks.
As an alternative please make another radio button there with even finer settings.
e.g.:
How about making a macro button that would change the mesh settings with a single click?
Since they are saved in the file and not in Rhino itself, it makes more sense to create a simple tool that stays with Rhino.
This would avoid the complications of saving, naming, restoring, exporting, and importing these settings.
Thanks @John_Brock,
That is also a good alternative.
Can you give an example?
This is a bit kludgy but works:
RH-58789 Refresh the mesh
RH-58789 is fixed in the latest Rhino 7 Service Release Candidate
