Wish: clipping plane with finite extent
hello,
as far as I know, clipping planes are always “true”, infinite planes. This limits the possibilities (such as clipping away a corner of a model or a piece of pie.
It would be cool if there could be the option of limiting the clipping to the part of the half-space which can actually be projected on the clipping plane Rhino object (which has physical extents).
Alternatively, a clipping object (such as a box) could be used to achieve a similar or even more powerful effect - subtracting temporarily parts of the model.
Many thanks!
You know you can have more than one clipping plane in a view, don’t you? Some experimentation will show you how they can be used together and whether you can get what you want.
yes I know, but certain things which I believe would be very useful are simply not possible with the current logic.
Here’s two examples:
I used to have an experimental feature in Rhino WIP for Raytraced where one could designate an object as clipping volume. Currently disabled though, but I hope to return to it soon.
Paid plug-in, but should do what is wanted in this case…
http://www.asuni.com/portfolio/dynamic-display-rhino/
it’s gone already. Do you have the name of this plugin?
This thread popped up due to a “4 years later” post.
I wonder whether “soon” has arrived yet? :slightly_smiling_face: :pleading_face:
In the scope of tectonic plate movements over 10 kilometers it is probably already yes, but for us: no.
