Hello, I was excited to use Rhino 8 with the clipping planes and depth feature, but it is not quite working like I’d hope, which was to have multiple clipping planes on a single object, basically showing “slices”. Was wondering if anyone has an approach for this so I can edit my shape and see it updated in real-time. Thanks!
i did not even notice the custom depth so far, yes that unfortunately does not work like it suggests, to me it seems to replace having to use a 2nd clipping plane from the other side which does not make much sense and is as unintuitive as it can get in my opinion. then rather having it work as you suggest would be better indeed limiting the range the clipping plane and not the depth. sorry i have no solution so far
