Yesterday my Rhino was updated to v.6.10.18311.2053, since then something seems wrong when viewing in wireframe mode. See attached files. It looks good when zoomed in but not when zoomed out.
Does anyone else have a similar problem?
Any help appreciated.
Hello - can you please run the SystemInfo command in Rhino and post the results here? thanks,
This is what I get from SystemInfo:
Rhino 6 SR10 2018-11-7 (Rhino 6, 6.10.18311.20531, Git hash:master @ 0f9089a0035dcc6955732d57071445ecc29390f0)
Licence type: Commercial, build 2018-11-07
License details: Cloud Zoo. In use by: cjanmark ()
Windows 8.1 (Physical RAM: 7.9Gb)
Machine name: LENOVO-PC
Intel® HD Graphics 4400 (OpenGL ver:4.2.0 - Build 10.18.10.3304)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.2
Shading Language: 4.20 - Build 10.18.10.3304
Driver Date: 9-9-2013
Driver Version: 10.18.10.3304
Z-Buffer depth: 24 bits
Total Video Memory: 2080 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.10.18311.20531
Hello - I do not know it that chip will work well with Rhino but I would check the Intel website (which can be a challenge) for a newer driver. Don’t necessarily believe what Windows may tell you about drivers being up to date.
I have not had this problem prior to the update yesterday. Is there some way that I can work around this?
-Carl
The best thing to do is to update the driver for that Intel 4400 display adapter.
You may be able to use this driver from Intel:
Any luck?
Thank you for all the help.
I updated the driver and everything seems to be working again (for now), the driver date is now 3-11-2014…
Sadly the same thing happened again with the latest update, does anyone know if it is possible to go back to a pre uppdated version?
Hi - if you are on automatic installations of Service Releases, a previous installer should still be available in one of the subdirectories of this directory:
C:\ProgramData\McNeel\McNeelUpdate\DownloadCache
HTH, wim
