Having problems with viewing model in shaded and wireframe views. If I zoom out a little bit from the model, the display colors get out of whack.
This is what I am seeing:
Hello - it looks like your model is over the World origin but it could be a custom CPlane showing - can you confirm that the model’s not out in space? If it is not, then can you run SystemInfo command in Rhino and paste the results here, and if possible post your model or send to tech@mcneel.com
Hello - thanks. That driver date is what leaps out at me - that is ancient history as these things go - I would see if there is an update available from Intel’s website and install that. That said, I’m not sure how good it will get with that video chip.
Understood. I am looking at intel to try an update that. However, this problem only started yesterday, and I have been working on that model intermittently for a few weeks now. Is there anything else that might work?
I believe it did, but that normally occurs when I shutdown or turn on my device, but I am not 100% positive as I do not normally pay the device much attention until I am prompted to login to it.
