In the file below, from Front view call Wirecut, select the 4 red lines, as cutting curves and the two solids as objects to be cut. Then choose the following options:
Direction=CPlaneNormal DeleteInput=No BothSides=No KeepAll=Yes
Press Enter to cut through the objects.
Looks normal at first glance, but if you start clicking on the resulting split boxes, you will see that they are now a collection of overlapping boxes of various heights instead of having just been simply split into 10 separate parts.
I tested in (7.12.21285.17001, 2021-10-12), but not in the WIP as it’s not installed on this machine.
WirecutResult.3dm (89.9 KB)
