Continuing the discussion from Simple Boolean Split fails?:
Using the two lines from which the planes were extruded as the cutters, _WireCut fails to split the torus too. Furthermore, they won’t split a simple box correctly.
However, if you join the curves first so you have a single cutter then both splits succeed.
simple wirecut.3dm (181.6 KB)
Regards
Jeremy
