Wire thickness Rhino WIP
Hi , is there a way to reduce wire thickness in RH WIP - GH
this is how they looks like in RH8 ( points are visible )
in RH WIP its hard to see the points
I presume you mean curves on the Rhino canvas. I don’t think you have access to the preview line thickness but hopefully the McNeel devs will tune this up.
In the meantime, you could change the Preview Point Flavour temporarily to show Points (balls) or Crosses to improve point visibility.
HTH
Jeremy
Hi @jeremy5 and thanks for your suggestion
yes i was referring curves on Rhino viewport , the points are hard to see but increasing point dimension could be a temporary solution. I hope they will fix thickness of preselected curves because it’s way to big.
cheers
This is bugging me also, I would like to see the old curve display thickness restored.
RH-99651 is fixed in Rhino 9 Service Release 1
