Linetype width?
When I draw a line, the thickness of the line is too thin and hard to see. How can I draw the line thicker?
If curves seem too thin on your display, you could go to Rhino options and adjust your display modes so the scale setting on curves is a value larger than 1.
Another option would be to use the TestWireThicknessScale command in Rhino and adjust the global thickness applied to all wires in all display modes.
