Wip technical view print bug
hi,
testing latest wip.
vector output is unidentifiable bunch of lines with objects which are not even turned on
raster gives what is there at least
i can send the file but privately
far from origin gives terrible results as well, when i moved it close to 0 it crashed…
Hi Ivan -
Depending on what’s in the scene, it’s possible that this is already filed.
As always, that will be necessary, yes…
have just sent to tech@mcneel.com
Hi Ivan -
Thanks, Mary wrote up a bug report for this issue.
I ran into quite a bit of crashing with that model here as well. That appears to be fixed in the latest in-house version now.
Just to make sure, though…
Your title for this thread is “Wip technical view print bug”.
Your screenshots, on the other hand, do not appear to be of a technical display mode. Or is that a modified version of one of the technical display modes?
When I open the file that you sent, it looks quite a bit different than what you show in your screenshots, so we’d need to have the exact same state of layers and hidden geometry to be able to reproduce that part of a possible issue.
open the file, switch to technical view
turn off all the layers
then turn on only steny,priecle,zakladove pasy
try to print in vector
then turn off all except priecle
try to print again, there will be ghost lines from turned off layers.
hi @ivan.galik thanks for pointing out the technical view bug, I could repeat it and logged:
RH-77340 Print and preview are showing lines of hidden geometry
RH-79199 is fixed in Rhino 8 Service Release 4 Release Candidate
