Here they show up (albeit with other issues). Is this something that you can reproduce with a simple box or two? If so, please post that 3dm and the output from the Rhino SystemInfo command.
@wim
I understand that vector printing for Technical is a new feature. I’m attaching an example (simple box) where it is not working as expected.
what makes technical special is the ability to show the hidden lines as dashed and this time in vector printing the dashed lines are either of a different scale or non existent. here is the viewport vs. printing:
After battling this bug for a bit now I finally was able to figure it out and reproduce the issue!
This is separate from the bug that was logged by @brian in @tay.othman’s post above.
Steps to reproduce:
-Have some non-nurbs geometry in your model
-Create a new layout and detail view showing this geometry on a sheet
-Add a clipping plane that cuts some portion of said geometry
-Make sure the layout/detail view is set to Technical Display Mode
-In Print Preview/PDF Printing, Raster will show the geometry, Vector will not
Please note that if you simply print a “Top” viewport view, the geometry will show up. It appears to be a bug occurring within the detail views/layouts only.
Unfortunately I cannot print my document set until this is resolved so I’m glad at least to have finally narrowed it down!
Furthermore, it appears that once the bug is “introduced” it cannot be rectified with simply deleting the clipping plane, where as copy/pasting the geometry to a new file will work but deleting the clipping plane in the existing bugged file will not fix the printing.
@Gijs thanks for testing. I didn’t realize there were two SRCs available yesterday the 12th? When I checked via Help->Software Updates it downloaded an updated 8.2.
Thanks, I’ll test on 8.3
EDIT:
Unfortunately the file still does not work for me. Are you using the Technical Display mode @Gijs
EDIT 2:
It appears to be unrelated to the clipping plane upon further testing as I’m able to reproduce in a new file without a clipping plane present, please see the video here:
Please see the simple “box test” file where non-nurbs geometry box will not be printed Vector but the box turned into a subD will in fact print Vector in the Technical Display Mode.
I tried to do exactly as you do in the video, but here it just works with vector/technical.
I do want to rule some things out though, can you do the same in a new file, but then don’t fiddle with the new features of the layer panel (to hide things from new details)
Edit: OK I see you did that already in the last file. But that file looks ok here too.
I am on 8.3.23347.1001, so that might be it, I’ll send you a link
I start a new file, draw a box, and attempt to print a detail view/layout of said box with Technical Display mode as a Vector PDF.
When that didn’t show I remembered the post about NURBs so I then converted the box to SubD side by side and that prints just fine but the original box still does not.
