I’ve tweaked the look of the Skylight shadow effect in Rendered mode to be more pronounced, and have a larger radius.
The radius is now 3x larger, which means shadows from nearby objects will, in general, cover a distance that is 3x larger than before. In practice this means you will see shadows cover more of the image.
The shadow intensity has been upped 2.5x times, which results in darker shadows.
Due to increasing the radius the shadow might look a bit more grainy.
I welcome any and all feedback on the new look. Also, if you think the display performance is too slow with the skylight shadows enabled, let us know.
Would you consider exposing the radius as a setting in the Rendering panel? Depending on the project type, scale and view, different values may be suitable. I’d love to see that controllable, now that the quality of new skylight shadows improved so much and made it actually usable compared to V5.
Yup - I split out those comments because I think it amounts to hijacking this thread.
However…I might be wrong. It could be that that bug is caused by the new changes to the skylight - but if they are, it’s absolutely fine to discuss that on the other thread.
