Hi, I’m having a display issue in the floor plan view with all the windows placed in a basement level right below the ceiling. As you can see in the attached images, the walls cut by the windows aren’t showing, only the window sills are visible.
Hi @Alessandro_Barbisan if those windows are located within a different level, they won’t show up in the level above, eventhough its Elevation cut plane is set to “Middle”.
Is that your case? if it isn’t, please share the file so we can revise it.
Hi @fsalla, it is not my case. The windows mentioned are on the same level that is currently active.
I have sent you the file to your personal email.
Ok, then send it please to visualarq@asuni.com or fsalla@asuni.com. If it’s a heavy file you can use https://wetransfer.com/ for example.
I have solved the issue. After your reply, I checked and found that the windows in question were located between a sublevel and an upper level. To fix the problem, I recreated the upper level and assigned the sublevel to the level in which the windows are contained.
BEFORE (no representation):
AFTER (right representation):
I apologize for the time you may have lost because of this matter, and I appreciate your patience and assistance.
Alessandro
I’m glad you found a solution for that!
