I ran into an issue with creating windows in VA, First of when I want to create a window on upper levels it projects the starting point to the ground level even if the plane is on an upper floor, secondly I do not see any proper preview of the windows in the Windows panel, does anyone know what exactly is going on?
Hi @dorisakooshki,
Is it possible that you have this option active?
If you disable it, you shoud avoid this behaviour.
Which template are you using? Which units? Does this happen in an specific file or template?
