When I insert a window I can choose the value for the elevation parameter only from the ground level (example 4.10m) not from the active level (example 1.00m)… I did a mistake somewhere?
I think what your talking about is loosely connected to this thread… in terms of objects associated to levels rather than origin or a base datum.
@lucavsnt When you insert a Window or a Door in the model, the Elevation parameter in the insert dialog is related to the Elevation of the Level where you are inserting that Window/Door.
Later on, when you check the parameters of that object in the Properties panel, the Elevation property is related the global Z coordinate of that object.
