Is it possible to set the defult elevation of the windows to a different height from the 1 meter that appears in the initial window. Our standard height is 105 cm and I would like if I did not specify otherwise it will be 105 and not 100.
@11170 The insert dialog of VA objects remembers the last entered values, so if you insert a window and change the Elevation in the insert dialog, the next time you run the window command, you will have the last entered Elevation value.
Is it possible that it will be in relation to the floor and not the absolute height?
That’s planned for future VisualARQ versions.
