Why rhino for vray gpu render is problem
Could you elaborate it more?
Could you give us context and brief description of the problem?
Could you give us the file you’re using so we can check it directly?
What i see look like the intensity of the lamp should be bumped to a higher value.
If 100 isn’t enough increase it to 1.000, 10.000, 1.000.000. It’s all normal
