Why isn't this curve Filleting?
Specifically by radius with Fillet component. Fillet Distance seems to work but is not what I need.
Rhino does it just fine with radius.
can you fillet this curve.3dm (36.5 KB)
my first thought was to use circle tan tan, but that wouldn’t allow for just picking the radius you want… so I tried to pierce a little hole in the opposite side of the curve so it’s actually two distinct curves, and it works fine:
Circle_Tan_Tan & Company.gh (19.3 KB)
I don’t completely understand where the problem is, I think it’s somehow linked to the curve being composed of just a single segment bent on itself
I need to use Fillet component. Not Fillet Distance.
Hm, interesting, thank you. Might be a possible work around.
I mean, it’s just a normal closed curve with a sharp corner.
Sometimes fitcrv helps
