Fillet vs. Fillet Distance... Unexpected behavior
I’d really like to use fillet distance, however it doesn’t seem to want to do anything with some of my closed curves that were made with Brep | Brep.
Fillet gives the expected result, in terms of not ignoring the shape altogether, I just want the setback fillets instead of radius fillets.
Is there any trickery I can apply to the problematic curves to make Fillet Distance accept them?
EDIT: Specifically it’s when the intersection has any curvature. If I Brep | Brep planar surfaces, Fillet Distance seems happy to work with that result. It’s just when one of the inputs has some curvature it stops working.
This component seems content to do absolutely nothing.
240624_IMG_Lazy component.gh (5.4 KB)
Thanks for giving this a nudge, I have created a ticket at https://mcneel.myjetbrains.com/youtrack/issue/RH-82697 and I’m currently working on fixing this.
Hi Menno.
I have the same problem and I see that you created a ticket and fixed this.
Does it work on Rhino 8 only? I’ve Rhino 7 and the component doesnt work on polycurves.
Thank you.
Yes this fix is only in v8 and v9-wip.
