So when you select two single faces to bridge in SubD, it creates a bridge with a nice rounded profile. However, in my case, I’m trying to make the hole opening bigger, but because my faces are so small, I am selecting a cluster to bridge, and the result is a square profile, even with the straightness all the way to zero. Might anyone know a workaround, please?
I added a Make Circular feature to my Selectinator plugin (v1.1.0) which is live on the PackageManager command now for Rhino 9 and 8. It does more than arrange the vertices of a SubD face selection border in order to get a better circle. I hope it helps
it makes a huge difference if Control Vertices are aligned to the circle (left) or the surface Points are aligned to the circles (right)
(top: box-mode, bottom: smooth mode)
typology
most times i use a typology based on a 2x2 or 4x4 square, still nice if subdivided to 8x8.
at least my experience - its nice to keep all features / edges by 2,4,8, or at least even.
