if the command at least would have the option to fix one end point. currently when trying to edit the entire thing moves.
also it is extremely rigid, asking me for an edit point to select but when moving most of the entire curve moves with it, actually the entire curve moves as described above but there seems to be some bias to it.
i must say right now in its current implementation the command is a waste of time and does probably not fulfil any kind of endeavours, or is there any user case where the current command really helps? maybe its just the mac version that is broken ? or maybe i really dont get it?
i found one topic in which kangaroo was utilized, i would think the command should work like this much rather?
