Rhino 7 SR36 Lands Design 5.8.3.9064
Hi @Lay,
Is this happening for all species or is it only happening for that 2D representation?
The file where that 2D representation is defined shoul be in the following path: C:\ProgramData\AsuniCAD\Lands\Rhinoceros (64-bit)\Blocks\Plants\Crowns
Do you have a square surrounding the object in that file?
Found out : it happens when Realistic is not on 3D
It happens because, even in the top view, I need to keep a view on the terrain. To make the meshes of the terrain visible, I have to press the 3D button in the LandsDesign panel. This action activates the “Plant 3D display” that may display the squares.
Exactly! Great to see you found it out!
