Only realistic 3D visualization showing in model
Hi!
I have a problem with 3D visualizations of trees from the plant database. My model only show the trees etc when i have the realistic plant display checked. It worked initially but then it didn’t so i opened an earlier version of the model and then it worked again with all the types of 3d display types. Now it has happend again and I cannot open an earlier version unfortunately, since I have changed too much since then. I can share parts of the model if nescessary.
Best regards
Johannes
Hi Johannes,
Yes, please, could you send me the file here or to landsdesign@asuni.com?
Hi, I think I accidentally opened the corrupted file again. Found the working version now. I transfered all the things I had changed via exports. So it’s ok! I think it’s just this version of the file that has become currupted somehow. I will write an email if it happens again!
Best regards
Johannes
