Why Can I never get _scale to work?
Methodology
select item (in this instance an image)
type scale
@ Base Point (press enter for automatic) type [Enter]
@ Scale Factor or first reference point type [4]
result nothing happens
why is this ?
Hi Bill -
Good question, that works fine here.
Please post both a 3dm file that can be used to troubleshoot and the output of the Rhino SystemInfo command.
Thanks Wim, I created a ‘clean’ file without any copyright stuff and lo and behold it works perfectly !! very odd… can I send original file privately ? what’s the best way to do that ?
Hi Bill -
Use Rhino Accounts and make sure to put a link to this thread in the comments field.
Thanks Wim,
I’ve done that now,
Hi Bill -
I looked at your file and am afraid that works just fine here.
Could you please add the SystemInfo data here?
I’m away from my PC until Monday
This is a System Info i posted on previous post - nothing much has changed other than auto-updates of Windows / Rhino / Intel drivers… although will post up to date on Monday
Rhino 8 SR14 2024-11-27 (Rhino 8, 8.14.24332.15001, Git hash:master @ 88c7b9834e34675b017e14ad488ef774e444793d)
License type: Commercial, build 2024-11-27
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.7
Computer platform: LAPTOP - Plugged in [71% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-22-2021 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 9-26-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 565.90
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-26-2024
Driver Version: 32.0.15.6590
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24332.15001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24332.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24332.15001
C:\Users\ambro\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24332.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24332.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24332.15001
Hi Bill,
Do you perchance have the Rigid option in Scale turned on? The Rigid option keeps objects the same size, while altering the spacing between them. To scale objects you need it turned off:
HTH
Jeremy
No, but thanks. I wasn’t aware of that option
Here’s correct systeminfo
Rhino 8 SR17 2025-3-4 (Rhino 8, 8.17.25063.13001, Git hash:master @ c65802ca75d5024ddf5b5197f19835a008a846a2)
License type: Commercial, build 2025-03-04
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.7
Computer platform: LAPTOP - Plugged in [78% battery remaining]
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 12-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.36
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 12-3-2024
Driver Version: 32.0.15.6636
C:\Users\ambro\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.6.0.0\bella_rhino.rhp “Bella” 24.6.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25063.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25063.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25063.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25063.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25063.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25063.13001
Hi Bill,
First, you should disable Bella and test.
Go to Options → Plugins and search for Bella. Uncheck and restart Rhino. Test.
That is really the only difference between your computer and mine.
Keep watching for a repeatable set of steps.
If we can repeat it here, we can get it logged.
FYI, there is a newer nvidia driver for you get at your convenience.
Sincerely,
Mary Fugier
It’s not Bella… I had this issue before installing Bella
Could well be user error… I just can’t work out how !?
Hi Bill,
Is it just the image that won’t scale or anything at all in that file?
Regards
Jeremy
It’s a recurring problem i have … primarily (almost exclusively) with image files
