2nd day using rhino - I’m trying to scale objects but the scale tool is not working as I first learned. I thought 1.5 would increase size by 150%, instead the object is reduced to 1.5 units on the grid. Any ideas?
Hi jesseb- just set the base point for the scale, then type in 1.5 & Enter - don’t set a reference point. Does that do what you want?
Wow. So simple. Thank you!!
