test.3dm (172.4 KB)
- Open the attached file.
- Select the cube and run
_Scaleor_Scale1D. - Select one of the corners as the base point.
- Select one of the other corners as the first reference point.
- Start typing a number like
1.23456...to use as the new distance to that point.
- Command line clears after each keystroke
- Pressing
Enterdoesn’t change object scale. - Pressing
Esccauses technical drawing to fail.
Rhino 8 SR17 2025-2-12 (Rhino 8, 8.17.25043.10001, Git hash:master @ 384a84c165ff11e0681af87e076dd465f8a325d5)
License type: Commercial, build 2025-02-12
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX 2000 Ada Generation (NVidia) Memory: 16GB, Driver date: 9-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.39
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-10-2024
Driver Version: 32.0.15.5639
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.17.25043.10001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
