Hi Will - Hmmm - does it show up in DocumentProperties?
Hmmm - is this true with any file? You might try a reboot…
yes any file
been there done that
maybe I’ll reinstall…or wait till the next update
Hi Will - this worked, though, at some point, correct? I’d try to repair the installation.
Hi Will - close and re-open that panel (if you have not tried yet…)
yep that did it
btw the user text property goes in and out. usually it wouldn’t show if I run a huge grasshopper script I made with heavy use of HumanUI plugin. Not sure if it’s related.
and it doesn’t come back if I relaunch the tab
definitely something in the grasshopper script is messing things up
the location in DocumentProperties disappeared again after firing up that GH definition
I can’t share it but I can tell you that it may have untidy Ghpython code that might be triggering the behavior…
Hi Will - if you want us to have a look ‘off line’ please contact tech@mcneel.com.
