I work on Rhino 5 and I have a problem with the sun : when I activate it, the sun position settings pop up but not the date and location settings.
Should I allow these settings to pop up somewhere ?
Thank you !
Thank you !
Open your drawing. Go to the panels tab click the sun. Once it opens turn it (the sun) on, this should open all of your options such as location, date and time, sun position and such.
Hope this helps … Danny
Thanks for your reply.
I found the solution and this was actually pretty dumb : all I had to do was to uncheck "control manually’.
Hope this can help someone else.
