What rhino commands do you use on a regular basis and think others don't know about?
Everybody should have this one on their start-up list: TestRandColor :stuck_out_tongue_winking_eye:
Test commands can be hard to discover - the one that I couldn’t do without when having access to a dual-monitor set-up is TestMooCow - it now works fine in RH 6 and the WIP.
Finally, one command that I actually have in my start-up list is OneView with a 15º angle.
That’s actually quite useful for me sometimes. I have a "Clown"script that randomly assigns color to all objects I choose but this could work as well.
Who picks up the bill for therapy?
That IS the therapy. Changing landscapes and stuff.
w
Ah. OK. In that case, I’ll stay neurotic.
and how does one turn it off?
I think one of the biggest things that new users miss out on is this forum and the fact that so many on here love to help out. A couple of folks that have replied in this thread have written custom scripts that have really saved me time and made my job easier.
Thank Ya’ll
Brian
Select by brushing; my mod is RMB as 10 pixels while LMB (default ) is 40 pixels.
snap01%2012-7-2018
Run the same command again.
I tried that and it didn’t do anything (R5). I ended up closing out, no biggie except for a 5 min load of the particularly large worksession attachments I had going on.
A lot of useful info here ! :smiley:
What about making this discussion pinned ?
When I do that here the colors change back to before, also in Rhino 5.
I have an alias “hr” (hide rest) that runs invert then hide. It hides everything but what you currently have selected.
Hi Brad - see the Isolate/Unisolate commands in V6.
Type between to select the midpoint between two points. I tend to combine this with the mid onsnap to select the middle of a surface. There must be a quicker way…?
press ctl key and hover over snaps for ‘one time’ snaps…
also ctl+shift for some others (forgot they moved between from one place to other moving to 6)
Another great Rhino feature, that some may wish to remain hidden:
  1. Go to: https://discourse.mcneel.com/
  2. Start a topic
  3. Start with “Hi @pascal
  4. Get your answer
(It’s not a reall command per OP, but I am sure it will be considered for V7)
One hopes, at least…
Ditto that. I use Jarek`s Orient on Object every day. Could not live without it now.
I think distribute might be better in Rhino 6…but I am still in Rhino 5 with t-splines and use Pascal`s Distribute script almost as much.
Very grateful to have been able to use both scripts for years now.
