What method can I use to apply a JPG image to a surface?
What method can I use to apply a JPG image to a surface (Python)?
public static Rhino.Commands.Result AddMaterial(Rhino.RhinoDoc doc)
      // materials are stored in the document's material table
      var mat = new Material();
      mat.DiffuseColor = System.Drawing.Color.Chocolate;
      mat.SpecularColor = System.Drawing.Color.CadetBlue;
      var texture = new Texture();
      texture.FileName = "my_image.jpg";
      mat.SetTexture(texture, TextureType.Bitmap);
      var rm = RenderMaterial.CreateBasicMaterial(mat, doc);
      doc.RenderMaterials.Add(rm);
      // set up object attributes to say they use a specific material
      Rhino.Geometry.Sphere sp = new Rhino.Geometry.Sphere(Rhino.Geometry.Plane.WorldXY, 5);
      var id = doc.Objects.AddSphere(sp);
      var rhinoObject = doc.Objects.Find(id);
      rhinoObject.RenderMaterial = rm;
      rhinoObject.CommitChanges();
      doc.Views.Redraw();
      return Rhino.Commands.Result.Success;
I have another question.
On the flat figure I applied a texture image using flat mapping.
Both figures have the same number of faces.
How do I get the same texture in the 3D figure?
Same proportion.
My knowledge is limited to a little bit of python and Grasshopper.
