How to access file name for material color in Python script
I have a mesh with a .jpg image as a material. The name of the .jpg file shows in the Materials tab:
When Rhino exports this mesh, the reference to the .jpg file is included in the .MTL file:
How can I access the .jpg file name using a Python script? I looked over the Rhinocommon API but could not find where this name is kept.
Regards,
Terry.
Hi Terry- looks like:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_DocObjects_Material_GetTextures.htm
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_DocObjects_Texture_FileName.htm
may be a start. You’d need to get acces to the material via material index I guess.
Pascal,
Thanks for the references. I got this to work:
from scriptcontext import doc
from Rhino import DocObjects
mats = doc.Materials
for i in range(len(mats)):
	fileNames = set([text.FileName for text in DocObjects.Material.GetTextures(mats[i])])
	for fileName in fileNames: print 'Filename = ', fileName
which gave:
Filename = E:\MediumModel1p4MFaces16384x1Texure.jpg
Thanks for the quick help.
Regards,
Terry.
