I need to recreate some rather poorly defined lettering in a photo, a few lines of text as such,
with 90 degree corners to the characters.
Lacking a graphics prog I am up to speed on which has a decent trim command, I am using Rhino.
method 1. draw the centres of the strokes and then pipe command them.
How can I best convert the pipes into outlines so as to use hatch solid fill command before exporting as tiff ?
When you say poorly defined, do you mean you cannot determine if the character shapes are close to an existing font?
Or, you know they are not close to an existing font and you need to recreate it from a fuzzy or low quality photo?
I am asking because you could spend a lot of time on this, if an existing font would be good enough. There are some tools that can determine the font from an image.
they are ill defined, I need to trace them, there is no font that matches, it will take me longer to try and find a font for a WW2 item that exactly matches them than simply draw them.
at the very least, how do I convert pipe command result to outline only ?
What I see, “Make2d” packs these new objects in a frame(BoundingBox) and moves them to position 0,0
So there are two more steps: Use command _BoundingBox on old and new and move make2d objects to old position, takes a two…five seconds.
Correct me, but _Silhouette creates 3dcurves and no automatic trim, so clean up takes much longer
and Rhino help says: To create two-dimensional curves from the silhouettes, use the ProjectToCPlane command.
was that in use in WW2 by Germany ? (Military)
However on the item this is on, all the strokes are uniform thickness, so I would haves to edit each char to be so.
Apparently may also be know as GulimChe Regular http://fontsgeek.com/fonts/GulimChe-Regular
Fonts rarely have uniform stroke thickness, even if they superficially appear to be uniform.
Here’s an enhanced contrast version of your image. The original did not work very well for the automated identification as you suspected.
EDIT, its not a good match, the “d” does not match, and the “q” and “a” probably wont either.
