What is the requirement for mesh in Honeybee (failed example attached)
I’m trying to use LB/HB to analyze the effect of tree canopy to the environment around ground.
  • When using simple BREP, things went well.
  • When using the HB_planarize_Brep analyzation also works.
  • When using default Rhino’s mesh, things doesn’t work.
  • When using my customized mesh (created from convex hull points), things doesn’t work.
And as my mesh is a direct export from a plugin I wrote, I cannot convert it to Brep, and then using HB’s meshing plugin to make it work.
The things that confused me a lot is what is “correct” mesh format for HB Shade? I know it is related to the meshing quality, but it seems I cannot find any guidance anywhere…
BREP:
Rhino’s Brep-Mesh
*HB-planarize-Brep - Mesh"
My exported Mesh (two version)
Hi -
Please use https://discourse.ladybug.tools/ for questions related to the Ladybug Tools.
@wim Yes, I tried. My post is currently on hold and my account is under check…
