Hi All
Need help, I would like to know what is the best way or the simple way to create the curve hollow pipe as illustrated:
ThanksPipe Section.3dm (340.4 KB)
Hi All
The original pipe was made mostly of two pipe-like surfaces. The spacing between the surfaces ranged from 1.57698 to 2.08365. I deleted everything except outer surface and used OffsetSrf command to make 2 unit thick pipe.
Pipe Section2.3dm (380.8 KB)
have you tried Sweep 2 Commands ?
As you have rails, will be more easy to do.
Hello - Not sure if this is what you’re after, but to build ‘by hand’ you can try what I outline in the attached file.
Pipe Section_PG.3dm (341.0 KB)
Hi Pascal, thanks for for the CAD unfortunately I’m unable to open the file due to my Rhino version is 4.0.
Here is that file in RH4 format…
Pipe Section_PG-RH4.3dm (367.5 KB)
Ya, works well. Thanks
Thanks alot.
Thanks for the file, is great.
